Learn how Alicona’s 3D measurement device helps you improve process monitoring in micro machining:
- Effects of surface finish on tool performance
- Optimize machining processes through highly reliable 3D measurement data
- Share visualization data with your clients to promote your machine platforms
Alicona Webinar
Title: 3D Measurement Capabilities for Professional Process Monitoring
Date: 6.8.2013
Time: 10:00 AM – 11:00 AM CDT
Speakers: Brad Etter, Alicona Sales Manager US & Brian Kyte, Alicona Sales Director UK
What you can expect:
- Case study: How surface finish affects performance
- Alicona’s solution: Focus-Variation
- Live demo: Automatic edge measurements*
- Modules: Measure radius, angle, wear, difference between target and actual – regardless of coating
IF-EdgeMaster
The IF-EdgeMaster is an optical 3D measurement device to automatically measure cutting tools. Typically, the system is used to measure cutting edges regardless of type, size, material or surface finish of the tool. Users measure radii > 2µm as well as rake, wedge and clearance angle of cutting edges. Both waterfall-type and trumpet-type are precisely measured. The robust technology of Focus-Variation delivers stable and traceable measurements also in a production near environment.
