OAV Air Bearings announce A&AT as distributor of South Korea
OAV Air Bearings – the leading manufacturer of the recently advanced frictionless air bearing technology – is pleased to announce the addition of A&AT as Distributor of  S. KOREA.
A&AT was founded in 1996 and specializes in sliding bearings, linear bearings, magnetic bearings and air bearings. With the addition of the OAV Air Bearing product line, A&AT can now extend their capability to be able to fit their customers with the ultimate precision, smooth motion, no maintenance, and high-repeatability solution.
OAV Air Bearing brings an Aerospace background to the design and manufacturing of precision porous air bearings. Because of this, OAV is very equipped to provide a solution which in many cases makes new technologies possible. OAV Air Bearings, made with 7075 Aircraft Quality Aluminum combined with special graphite, offer many benefits over traditional bearings:
Advantages of OAV Air Bearings over Contact Bearings
-No Friction
-Indefinite Operating Life
-No Maintenance Required
-No Heat Generation up to 140,000 RPM
-High Accuracy
-High Speeds
-Clean Air
-Reduced Vibrations
-Damping Effect
-Easy Installation
-Can often replace conventional bearings
-High Stiffness
-More resistant to shock loads
-Operates over wide range of temperatures
-No Noise
-Resistance to Dirt
-Self-lubricating Material
-Corrosion Resistant
Learn more about OAV Air Bearings:
http://www.anat.co.kr
http://oavco.com/
OAV Air Bearings
Carnegie Center, Princeton, NJ 08543
