Introduction
JTEKT Europe Bearings, the bearing division of JTEKT Corporation (formerly known as Koyo Bearings), specialized in the design and engineering of a wide range of rolling bearings for numerous applications, ranging from automotive and windmill applications to aerospace and tunnel drilling equipment, is now introducing the JHS® roll neck bearing series for use in Steel production equipment.
Background
Bearings used for steel mill roll necks (Fig. 1) must cope with heavy loads and high-speed rotation, under harsh conditions. In order to respond to these needs, JTEKT is permanently working to resolve related issues, such as developing better bearing materials and improving the bearing seal performance.
The challenge
Steel production equipment is operated in extremely harsh environments, where machinery is exposed to high temperatures, water and mill scale (a film of iron oxide that forms during the processing of hot iron). The bearings used in this equipment must continuously withstand heavy loads under high- speed rotation conditions (Fig. 2). Also the oil seals needs enough sealing performance to withstand such harsh conditions. The newly developed product has been designed to improve the sealing performance and to significantly reduce the temperature increase and the amount of water intrusion, thereby contributing to a longer bearing service life and a reduction in maintenance costs for our customers.
The solution
1. Change of the oil seal shape
By performing analysis on each design factor of the shape of the oil seal lip (the portion circled in red in the diagram to the right), we fundamentally reviewed the shape (Fig. 3).
2. Leading to a longer service life
Thanks to this, we were able to succeed in maximizing the pump force (the force that prevents intrusion of water and foreign matter) and reducing the amount of water intrusion into a bearing by more than 70% compared to conventional products (Fig. 4). In this way, we were able to reduce sudden bearing damage resulting from deterioration in lubrication, and achieve an oil seal with a longer service life than conventional products.
3. Reducing cost by application of nitrile rubber
By changing the shape of the lip, the temperature increase of the oil seal was reduced by 30% compared to conventional products (Fig. 5). This allows for the application of NBR (an inexpensive oil seal material widely used in bearings for steel production equipment) within the operating temperature range.
The results
JTEKT’s permanent challenge is to reduce customers’ maintenance costs.
With these improvements we realized both direct cost reductions (by applying NBR oil seal) and indirect cost reductions (by increasing service life).
General notification
Koyo Bearings has been officially rebranded to JTEKT Bearings as of April 1, 2022. Please appreciate that this is only a change of brand. The company, its general structure, the products and services will remain the same. Our customers can rely on the continued good service and quality of our products in the future and our commitment to keep the same excellent business relationship with our valued partners, as in the past.
Please do not hesitate to contact us or your distributor in case you would like to have more information about our company, products and services. Get to know our bearings at www.koyo.eu
This article is published in BearingNews June 2022 issue
