The drive #chains are automatically lubricated in a large bakery in Switzerland.
Increase machine availability with #simalube and reduce costs at the same time
simalube lubricates chains in any industrial environment, efficiently and reliably. A continuous #lubrication with simalube prevents premature damage, reduces maintenance costs and increases functional reliability. In companies where a lot of dust and dirt occurs, cleaning the chains is just as important as lubrication. This cleaning is always guaranteed by using the simalube brushes.
Detailed information: https://simatec.com/products/simalube…
simalube lubricates chains dosed and precisely
The #simalube dispensers are ideal for use in dangerous and difficult to access places. Once installed, the #lubricator supplies both the chain and the sprockets with lubricant evenly and reliably and for up to a year. With the extensive range of simalube accessories, the lubricant dispensers with brushes can be optimally and professionally installed and adjusted to the corresponding #chain applications. The exact dosing and precise feeding reduce lubricant consumption significantly.
simalube application areas for typical chain applications:
- Conveyor and conveyor belts
- Escalators
- High-speed chains
- Hinged belt and roller chains
- Joints, slideways and rails drying systems
- Chain drives
- Transport facilities
Advantages of simalube lubrication systems:
- Proven lubrication system for all types of chains
- No oil puddles on the floor, no pollution of the surroundings
- Reduction of service and maintenance costs: there is no need for manual lubrication, so there are fewer operations and the time saved is massive
- Rust, loud running and squeaking of the chains are avoided by the simalube chain lubrication
- No need to switch off the machines during maintenance
- The precise lubrication extends the life of the chains significantly
- Suitable solution for every chain thanks to individually applicable accessories
- Once installed, the chains are reliably and continuously supplied with lubricant and cleaned
Website: https://simatec.com/products/simalube…
Flyer: https://simatec.com/assets/Documents/…
Facebook: https://www.facebook.com/simalube/
LinkedIn: https://www.linkedin.com/company/sima…
