Environmentally friendly Rust Revenge®, new from Daubert Cromwell, is a water-based, non-acidic, ready-to-use soaking liquid that removes rust without mixing or scrubbing. Tested and approved by leading OEMs, Rust Revenge begins to work in as little as 5 minutes. It is non-toxic, biodegradable, reusable, and entirely safe for use in the workplace.
Rust Revenge, new from the leading manufacturer of anti-corrosion packaging for industry, is a low-foaming rust remover and descaler that solves a common problem in metalworking industries. It is highly effective at removing scale, hard water deposits, and build-up. Ideal for de-rusting metal equipment and machinery in automotive, heavy equipment, military, and all types of manufacturing applications.
Odor-free, ph-neutral Rust Revenge contains no VOCs or HAPs, acids or bases. Use it directly as supplied, without further dilution. Intended for dip or immersion tanks, adding to spray wash systems, and spot-treating problem areas on metal surfaces. For best and long-lasting corrosion protection, package the clean part in Daubert Cromwell VCI film or paper.
Rust Revenge is available in 1-gallon, 5-gallon, and 55-gallon containers, plus totes. For more information, contact Daubert Cromwell at +1-708-293-7750; [email protected].
