Sprayon® Products, the long-standing leader in delivering reliable, innovative solutions for the most demanding industrial and MRO applications, is proud to introduce the LU™205 Food Grade Chain Lubricant as part of our expanded line of NSF® H1-Rated Food Grade Lubricants.
Sprayon® LU™205 Food Grade Chain Lubricant is a blend of the finest quality renewable resource oils available, treated with the most effective anti-oxidants, extreme pressure, anti-wear, and corrosion protecting additives. PTFE is added to further enhance load capacity and reduce friction. LU™205 Food Grade Chain Lubricant offers excellent extreme pressure lubricity, water resistance and high temperature performance on chains and much more. Foaming action allows for pin-point application and deep penetration.
FEATURES:
• NSF® H1-Rated (Registration #145282)
• Extreme Pressure Lubricity – Falex Load (ASTM D-3233A): 3,750 lbs; 4-Ball Wear Scar (ASTM D-2266): 0.44 mm
• Foaming action for pin-point application and deep penetration
• Excellent water resistance and anti-wear properties
• Free of Heavy Metals
• Temperature Range: 12?F to 450?F
• Rapidly Biodegradable (OECD-301)
To learn more about Sprayon LU™205 Food Grade Chain Lubricant (and request a FREE SAMPLE), the entire Sprayon NSF® H1-Rated Food Grade Lubricants Program and our revolutionary Sprayon® System which helps facilities extend & sustain 5S Visual Management to the use of their chemicals and lubricants, please visit FoodGrade.Sprayon.com or Sprayon.com.
About the NEW NSF® H1-Rated Food Grade Lubricants Program from Sprayon® Products
For years, the Food Processing Industry has had to accept white mineral oil as the universal lubrication choice for all applications. While this was certainly a better alternative than no lubrication at all, white mineral oil has its limitations in meeting the various lubrication challenges that are unique to Food Processing facilities.
Sprayon’s NEW H1 Food Grade Program features twelve (12) lubricants which were specifically developed to answer the needs of this very broad and demanding environment. These lubricants were designed to specifically address the performance and application needs of today’s food processor. With heavier load pressures, superior resistance to water washout, lower flammability ratings and wider temperature ranges, our offering was specifically designed to preserve and protect your valuable equipment to prevent costly breakdowns and ensure maximum performance.
And the NSF Certification and H1 Rating of our Food Grade offering gives you the confidence of knowing our products and processes are in compliance with internationally accepted food safety standards. With Sprayon’s NEW H1 Food Grade Lubricants, you can truly keep your operation safely running at peak performance.
Visit FoodGrade.Sprayon.com today to learn and to request your FREE SAMPLES.
About Sprayon® Products
Established in 1968, Sprayon® Products has a long-standing leadership position as the brand that delivers reliable, innovative solutions for the most demanding industrial and MRO applications. For over 40 years our goals have been the development and continuous improvement of products and services which will help our customers:
• Preserve & protect their valuable equipment to prevent costly breakdowns & downtime
• Become more efficient… more productive… more profitable
• Work smarter… safer… better
• Promote the continuous improvement of all their processes
Our understanding of the complex needs of the industrial and MRO space has been the catalyst for the proven performance which Sprayon delivers across a broad range of the highest-performing Lubricants, Electrical & Electronic Products, Cleaners & Degreasers, Mold Release Products, Welding Products and Specialty Application Products. It has also led to the development of innovative technologies like our Eco-Grade™ and Liqui-Sol™ Programs which help any facility operate more safely without sacrificing performance. In 2010, we developed The Sprayon® System which integrates the labeling on Sprayon Product Packaging with a unique set of identification tools to help any facility implement and sustain 5S Visual Management in the use of their chemicals and lubricants.
Please visit Sprayon.com to take a look at everything Sprayon has to offer and contact us (800-SPRAYON or Sprayon.com) with any question you might have. We look forward to working together to help you take your operations to the next level.
source: ThomasNet
