The Permaglide® P180 material has raised the bar in bearing technology, surpassing all previous standards. Known for its outstanding performance in both dry and wet conditions, this new all-rounder offers exceptional durability and efficiency, making it the clear winner among P1 materials.
Outstanding Features of Permaglide® P180
When comparing materials, it’s crucial to look at how they perform under various conditions. In recent plain bearing tests, P180 demonstrated excellent results in dry running, wet running, and erosion provocation, making it stand out from other materials in the P1 category. These results confirm the P180 as the new universal solution for applications requiring high performance.
The Advantages Over P1 Materials
The wear on plain bearings is a complex process, influenced by mechanical, dynamic, and tribological factors such as lubrication and friction conditions. Additionally, the material properties of the sliding partner—its material, hardness, and roughness—have a significant impact on performance. Testing under standardized conditions helps identify the most suitable materials for various applications.
The Permaglide® P180 material showed the lowest wear compared to other materials tested. It performed exceptionally well in both dry and lubricated applications, proving itself as a true all-rounder. This makes it an ideal choice for industries requiring reliable, low-maintenance, and high-performing bearing solutions.
Low-Maintenance and High-Performance: P200
In addition to P180, P200 is another lead-free material that provides very high performance and is extremely low-maintenance. You can learn more about P200 in our application example, “Bearings in Steering Pins of Potato Harvesters”.
Permaglide® P180: High-Performance Material for Demanding Applications
The new Permaglide® P180 has exceptional wear resistance, making it suitable for a wide range of applications, including fluid pumps and proportional solenoids. Its low wear in both dry running and lubricated environments highlights its versatility and reliability, ensuring its place as the top choice for demanding applications.
Application Example: Bearings in Fluid Pumps
Fluid pumps, which are used to pump liquids such as water or oils, require bearings that can handle a large rotational speed range and a narrow bearing clearance. Permaglide® P180 offers excellent wear resistance, high load capacity, and erosion resistance, making it perfect for fluid pump applications. The material’s high chemical resistance also ensures its suitability for use in various media.
Application Example: Bearings in Proportional Solenoids
Proportional solenoids, which are electromagnetic actuators used for small strokes, require bearings that provide a consistent low friction coefficient throughout the product’s lifespan. Permaglide® P180 ensures low and consistent friction, minimizing energy loss and reducing hysteresis. This makes it the ideal choice for bearings in proportional solenoids.
Conclusion
The Permaglide® P180 material represents a breakthrough in bearing technology, offering unmatched performance across a variety of challenging applications. Its low wear, excellent durability, and high resistance to environmental factors make it the perfect choice for industries that require reliable, long-lasting solutions.
Whether you’re looking for a material for fluid pumps, proportional solenoids, or other demanding applications, Permaglide® P180 offers the best in performance and reliability.
Find out why Permaglide® P180 plain bearings are ideal for use in proportional solenoids in our application example (ePaper FL 1702) or on the website.
