The OAV Roller Air Bearing is here to replace conventional bearings. No friction no contact, high speed, ultra precision.
A breakthrough innovation from OAV Air Bearings. An ultra precise, hard-installable replacement for conventional bearings. The result: no friction, no contact, no maintenance, no heat generation at high speeds, and an indefinite operating life.
OAV Air bearings have higher stiffness and excellent geometric performance. OAV Roller Air Bearings pre-loads both horizontal and vertical surface with opposing thin film pressure, this maintains the perfect gap with ultimate precision. OAV Air Bearings surface design equally distributes the air and pre-load over a entire surface area; the result is outstanding stiffness and maximized performance.
