ZEN Bearings is well known for the durability and reliability of its bearings. For over 50 years, the high quality of their products has helped millions of customers reduce maintenance costs and improve performance. The question arises: How does the brand uphold such unwavering quality standards?
The answer to this question is simple: Their Adherence to German DIN standards and their quality control process.
Excellence from Inception
Their quality control process begins at the source of the raw materials, where they exclusively collaborate with reputable, certified suppliers. This strategic approach empowers them to meticulously verify and maintain the quality standards of the materials and components they incorporate.
Seamless Manufacturing and Assembly
Rings, balls, and cages are precisely manufactured in their three German-managed factories. During assembly, advanced machinery measures all tolerances to ensure strict compliance with DIN standards.
Strict Quality Control During and After Manufacturing
Without exception, each of the over three million bearings manufactured every month undergoes not just one but two layers of quality checks. First, during manufacturing at their factories. Once completed, they undergo additional testing at their inhouse testing facilities: The ZEN
Quality Inspection Centre. This comprehensive process ensures that the bearings meet all stringent German DIN standards, providing you with products that are not only durable and reliable but also consistently high-quality.
The ZEN Quality Control Centre
The ZEN Quality Control Centre is crucial to the brand’s quality assurance.
This building covers 5,000 square meters in inspection facilities alone. It is ISO 9001:2015 certified and features state-ofthe-art testing equipment and a dedicated team of over 100 highly qualified inspectors working daily to ensure compliance with DIN standards. This facility operates with a German management to scrutinise each bearing meticulously.
All premises and testing equipment are certified with ISO 9001:2015, and their testing procedures and tolerances are set to German DIN standards. The globally recognised TÜV Rheinland accredits both standards.
Tests Performed at the ZEN Quality Control Centre:
- Visual inspection: The visual inspection is the start of their quality control checks. A trained eye can quickly determine any discrepancies or visible faults in the material or assembly.
- Rockwell Testing: The Rockwell test determines the hardness of the material by measuring the depth of penetration of an indenter under load.
- Radial Clearance Tolerance Testing: The radial clearance is essential to the operation of the bearing. Their machines are regularly calibrated to ensure the tolerances adhere to DIN standards certified by the German TUV.
- Inner and Outer Tolerance Testing: The inner and outer tolerance test measures the precise dimensions of the bearing. Again, their strict tolerances are set according to the DIN standards.
- Noise Testing: Highly sensitive microphones measure and identify audible peaks of a rotating bearing. These peaks can indicate faults in the raceways or possible grease pollution.
- Vibration Testing: Using high, medium and low range frequencies, the vibration test can identify a range of bearing defects, such as imbalance, play and misalignment.
Premium Individual Boxing
Each bearing is meticulously packed in premium bomaintain quality until their products reach you. This not only keeps the bearing in optimum condition but reflects the care and attention they put into their products and embodies the ZEN brand.
Quality Control Beyond Standards
In addition to the DIN standards and ISO 9001:2015 protocols, ZEN’s German management approach ensures top-quality products and consistent quality control across its global locations. Furthermore, their team goes the extra mile by implementing rigorous checking procedures. This additional step guarantees that the bearings you receive are in perfect condition throughout the production and distribution.
In conclusion, ZEN Bearing’s commitment to excellence permeates every aspect of its manufacturing process. With over 50 years of expertise, ZEN consistently delivers bearings that surpass industry standards. Explore their extensive catalogue of over 9,000 references at www.zen.biz and elevate your operations with top-quality products.
For inquiries, contact ZEN at sales.uk@zen.biz to experience the difference firsthand.
