Canada, 21 October, 2013: World biggest Bearing Interchange & Bearing Application Database (BIAD) will be a revolution for bearing selection, finite element analysis and bearing life calculations. A useful tool for all bearing traders worldwide..
The database will cover the designations and bearing frequencies information of more than 1000 bearing companies worldwide. Apart from the interchange between the designations, the database will also be able to provide the bearing frequencies information based on given RPM in more than 96 categories /types of bearings.
The total data in first phase would be more than (1.8 Million) 1.800.000 for interchange designations and around (0.44 Million) 436.000 for bearing frequencies.
Apart from above databases, the BIAD will also be able to simulate the Finite element analysis of bearings which will have a turnaround time (procession time) between 8-16 hours, based on load conditions.
Typical User Scenario:
Users of the database will be able to search for any bearing in the database and select the companies for interchange required from 1000 companies,
1) look and check up for the same bearing designation for Bearing Frequencies and Harmonics Data at a given RPM .
2) look and search in database for the same bearing designation with respect to its application. Means this particular bearing is used for which applications.
3) User can also look for interchange based on Application area
Example :
- Aerospace
- Agriculture
- Cars & light trucks
- Compressors
- Construction
- Electric motors
- Food & beverage
- Home Appliances
- Industrial fans
- Industrial pumps
- Industrial transmissions
- Machine tool
- Marine
- Material handling
- Medical & health care
- Metals
- Mining & mineral processing
- Oil & gas
- Portable power tools
- Pulp & paper
- Racing
- Railways
- Skates
- Solar energy
- Traditional power
- Trucks, trailers & buses
- Two & three wheelers
- Wind energy
Within the designations interchange of 1000 companies (selectable), the database will be able to loop up for the same bearing designation the bearing frequencies data, application data and finite element analysis along with bearing life calculations.
The database is currently under development and testing phase and shall be released during 2014.
More detailed information and presentation of the BIAD software, the developer and detailed services will be presented in the BearingNews magazine.
Subscribe to the BearingNews magazine by clicking here
