Bearing Data’s Interchange System – overview
Bearing Data is the most comprehensive and reliable database of industrial bearings interchange and aims to become a global reference.
More than 3 million bearing designations are available in Bearing Data’s database, providing roughly 200,000 interchange reports from more than 100 of the most important bearing manufacturers worldwide.
In using Bearing Data, you can find several alternative brands for your bearing applications, coupled with a detailed explanation of prefixes and suffixes for all bearing designations, as well as cage material.
You can conduct searches by simply entering the bearing designation you wish to find cross-references for, and then receive a clean, precise report. It is also possible to print and save reports. You can also use the report for a quotation request, purchase request or even for detailed inventory control.
This product is the result of eight years of research on the part of engineering professionals with experience in many application fields who made this database project possible.
At Bearing Data, you’ll find standard bearings as well as bearings specifically designed for special applications. In terms of special applications, you can find bearings for high temperatures, electrically insulated bearings, bearings with special coatings, sealed bearings, ceramic bearings, corrosion-resistant bearings, split bearings, precision bearings, energy efficient bearings, special and large size bearings for the steel, paper and mining industries.
Benefits of the Interchange System
Bearing Data’s Interchange Reports match different manufacturer part numbers you may have in stock, thus reducing duplicate inventory, eliminating unnecessary purchase expenses, delivery waiting time and avoiding unplanned downtime.
Bearing Basket
Another Bearing Data feature is the Bearing Basket, which is a very simple tool that helps you find the bearing you need.
How does it work? Quite simple. Enter the data regarding the bearing you’re looking for (designation, quantity) and the part number will be uploaded into the Bearing Basket, which is a list of bearings on demand. The distributor with the respective bearing in inventory will send a quotation directly to your email.
You may find more information about this tool on Bearing Data’s homepage.
In just a few seconds, you’ll have all possible alternatives and can select best-fit based on the detailed specifications provided in our reports, as well as even optimize design cost. Finding options from alternative brands is another advantage of the system.
Bearing Data’s database is updated on a monthly basis.
Easy to use
The tool is easy to use and requires no training.
By entering information about a bearing (bearing designation, dimensions, clearance, tolerance, preload and manufacturer), Bearing Data will generate a detailed report for your search. You can also do searches by looking for a specific bearing type or for a specific bearing application. At Bearing Data, you will find more than 600 bearing types in order to obtain the best option for your particular application.
Summary
- 3 million bearings in the interchange database
radial bearings, precision bearings, axial bearings and combined bearings - Over 600 bearing types listed
- More than 100 manufacturer part numbers listed
- Search by part number, dimensions, bearing type or manufacturer
- Prefix and suffix descriptions
- Simple to use, no training required
- Easy and intuitive
- Comprehensive and reliable
Homepage
Visit our homepage now for:
- Sample reports
- Map of bearing types
- List of manufacturers
- User manual
email: sales@bearingdata.com
www.bearingdata.com
