JESA SA, is a company specialized in the design, development and production of customized bearings and integrated bearing assemblies. The company was founded by Joseph Egger in 1969 and begun trading in ball bearings before starting its own bearing production factory in 1971. JESA markets its solutions worldwide in sectors as varied as the automotive, textile, linear guidance, medical technologies, and others.
Since 2003, JESA also has a subsidiary in China to develop these activities and manage its network of subcontractors. In 2008, JESA expanded its activities in China by creating its own production factory of components and bearings for the headquarters in Switzerland.
The JESA group has been part of POLYGENA AG for more than 20 years and employs today 300 people.
More than 50 years of experience have made JESA the specialist in customized solutions, containing bearings and machined parts, together with engineering polymers.
JESA does not have a fixed product range that can be consulted in a catalogue. Each customer generates a different project, which then results in a specific product.
The JESA research centre, also based in Switzerland is at the leading edge of innovation. Its huge experience in high-end materials, bearing geometries and plastic injection molding creates a unique conception focused on the design of solutions adapted to the specifications of customers.
Jesa has recently released two new innovations that are now available on the market and presented hereafter.
SOLID OIL: The perfect lubricant for use in aggressive environments
In certain applications, ball bearings are required to operate in aggressive environments, causing recurrent failures and therefore high operating costs. These failures can be due to corrosion or pollution by particles that penetrate the bearing.
This is the case, for example, in production facilities in the food industry, which are often cleaned with hot water under pressure or with solvents, which greatly increases corrosion and grease leaching.
Jesa has therefore undertaken, within the framework of its innovation projects and with a specialized partner, to develop and validate a solid lubricant, commonly called “solid oil”, which is a polymer material saturated with synthetic oil.
This compound can easily be introduced into a ball bearing and heated so that the lubricant hardens and becomes a solid and porous matrix structure that will occupy all the available space inside the bearing around the rolling elements and the cage. This high fill rate gives JESA bearings excellent protection against moisture and dust while providing a very high level of micro-lubrication due to the amount of oil from the porous matrix.
This solution offers many advantages and is particularly recommended for bearings operating in an aggressive environment or where re-lubrication is difficult due to accessibility. The solid oil allows to increase drastically the lifetime of the bearings and consequently to reduce the maintenance costs. The compound is also InS-H1 certified and can therefore be used in many industries such as food, beverage, pharmaceutical, medical or textile.
TORLON® PAI: Very high-performance thermoplastic
The second innovation proposed by JESA is the injection process of high-end plastic TORLON® PAI. 3 years of development were necessary to validate this process and JESA is now part of the very closed circle of structures having this technological mastery, which naturally opens the scope of possibilities in the conception and production of customized bearing solutions.
Torlon® PAI is known to be the best performing thermoplastic that can be processed by injection moulding under certain conditions. It has exceptional mechanical properties combining the advantages of metals (high stiffness, low creep and very high wear resistance) as well as the advantages of thermoplastics (low density and good elongation factor). Due to its composition, it is also completely non- magnetic, non-oxidizable and dielectric.
TORLON® PAI is characterised by very high thermal stability with incomparable mechanical and chemical resistance compared to other advanced engineering plastics. The intrinsic properties of this material make it an effective alternative to metal in high-temperature friction and wear applications.
This material is usually machined, but it is also possible to shape it through a complex injection molding process. Indeed, this material is not injected like a standard polymer, very specific equipment and expertise in the field of polymers is required to maximise its properties.
This process has the advantage to provide tailor-made solutions with the possibility of making very complicated shapes. Another asset of injection overmolding is obviously the cost reduction due to the wasted machining chips saving.
Thanks to this development, Jesa can now offer to its most demanding customers a state-of-the-art material and process for developing unique innovative solutions in many fields such as aeronautics, the medical technology industry and food industry.
With its extensive know-how in bearing design and plastic injection molding, JESA is the ideal partner to solve your most complex problems and develop the most suitable custom bearing solutions for your needs. Do not hesitate to contact JESA if you have any specific bearing project, technical salesmen and engineering department will be happy to assist you in your development.
Visit the website for more information.
