COC present NEW spherical roller bearing units with innovative designs and features to handle the world’s power transmission needs. The recently launched innovative bearing units will be presented for the first time during BEARING EXPO India event which will take place on 15 – 16 October in Mumbai.
The features of COC spherical bearing units can be summarized as following:
- Contact Seal Protection: COC original designed seal maintains positive contact with the flingers at virtually any angle of shaft mis-alignment up to +/- 2°. The stainless steel flinger shields the seals and bearing from contamination and damage. Learn More
- Non-expansion to Expansion: When your application needs to be able to accommodate thermal expansion of the shafting, use only one fixed bearing on each shaft. By simply moving a snap ring on the back of the unit the bearing can easily be converted from non-expansion to expansion or vice versa. Learn More
- CROSSLOC™ & SN HOUSING: COC new adapter locking system with SN dimension housing is a unitized replacement for standard SN split housing units. It’s a great off-the-shelf solution you can save the time and money. 100% interchangeable with competitive SN products. Our SN are shaft ready units that are factory sealed, pre-lubricated, and assembled. Learn More
- Adapter Sleeves: COC units uses the adapter sleeves on the market in this locking system for the easier replacements and it can hold the under sized commercial shaft perfectly. It contacts between the shaft and inner ring just underneath the rolling rollers 100% concentrically. Learn More
- Scan QR code with COC App: Every single COC housing has a unique QR code with both the web link and serial number of the product, which will help you check availability to re-order or extend the warranty. Learn More
You can read the history behind COC or visit the website www.crossocean.com for more information about the COC spherical roller bearing units.
