How SDT Keeps You Covered for Life
Industrial companies are embracing predictive maintenance not out of novelty, but necessity. Unexpected equipment failures can halt production, erode profit margins, and damage reputations. Predictive maintenance (PdM) offers a smarter path: detect incipient faults early and act before they escalate.
But PdM is only as good as its weakest link , and all too often, that weak link is data integrity. If the sensors, receivers, or instrumentation drift from their nominal values, then the alarms, thresholds, and diagnostics will lead you astray. This is where calibration becomes not just “nice to have,” but absolutely critical.
The role of calibration in predictive maintenance
When your SDT device leaves the factory, it’s calibrated under controlled, ISO-based conditions to deliver accurate, repeatable readings. Over time, however, multiple factors can introduce drift:
- Thermal cycling
- Mechanical shock or vibration
- Changes in environmental humidity or contamination
- Aging of electronics or components
These shifts may seem small, but in condition monitoring, small deviations can cause false positives or false negatives, leading you to repair when not needed, or worse, miss a real fault.
By having your equipment recalibrated annually, you restore the “just like new” performance envelope. During calibration:
- Your device is connected to a highly accurate, traceable laboratory instrument.
- Hundreds of signal pulses are sent; measurements are compared against known standards.
- Deviations are logged, and adjustments are made to correct them.
- You receive a before/after report and a new calibration certificate.
This process ensures that the data you base your decisions on is trustworthy.
In fact, studies show that uncalibrated or miscalibrated sensors drastically reduce the ROI and effectiveness of predictive maintenance efforts, rendering the entire strategy vulnerable.
From calibration to confidence: the SDT Lifetime Warranty connection
At SDT, we link calibration directly to our Lifetime Warranty Program. Only equipment that undergoes annual recalibration remains eligible. Why? Because we believe that long-term protection must rest on accurate performance. If your device is drifting and reporting incorrect data, it no longer serves its primary role in predictive maintenance.
Here’s how the extended protection works:
- You register your product and commit to annual calibration.
- You send your device (and kit) to an authorized SDT service center for calibration.
- Upon recalibration, your device is certified and returned in full working order.
- If a repair or replacement is ever needed, it is covered under the lifetime warranty (provided calibration is up to date).
Thus, calibration isn’t just a maintenance step, it’s a gateway to lasting peace of mind.
What happens if you skip calibration?
Skipping calibration isn’t just risky, it may void warranty coverage. Without yearly calibration, your data integrity is suspect. In many industrial and regulatory contexts, that alone is grounds for rejecting warranty claims.
Furthermore, poor data can lead to misallocated maintenance, excessive downtime, or undetected equipment damage. In the world of high-stakes machinery, those consequences are steep.
Tips to maximize calibration value
- Track your calibration due dates: don’t let them slip.
- Return the full kit (sensors, charger, accessories) to be fully verified.
- Use the original storage case : it protects the unit in transit and avoids damage.
- Review the before/after report carefully : trust but verify.
- Build calibration cost into your predictive maintenance budget, not as an afterthought.
Conclusion: Calibration powers trust
Predictive maintenance is a powerful tool, but only when built on solid foundations. Calibration is that foundation. At SDT, we don’t just sell instruments; we commit to maintaining their precision and longevity. Through our lifetime warranty (contingent on annual calibration), we take on the burden so you can trust your tools, your data, and your decisions… for life.
